Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Installation & update
Installing or updating your app. Hardware/software requirements, OS specs.
A Strange Text Problem, Please Help
Hi everybody,
This is my first time in this forum and i need some help.
I'm using ArchiCAD 6.5 for many years. Recently I'm having a problem that I couldn't solve and couldn't understand why it happens either.
When I write a text line beginning with a number (e.g. "60 cm. away") it appears on the screen "cm. away 60". The same thing happens with the "+" and "-" signs too. When I print it from the printer (HP 1220C) it prints out the wrong way ("cm. away 60")
I couldn't understand why this problem suddenly occured and couldn't find a solution for that.
Any help will be very appreciated.
Thank you.
3 REPLIES 3
Baran wrote:
Hi everybody,
Thank you.
I'm guessing you are using Windows as your opertating platform.
In CONTROL panel > REGIONAL SETTINGS you will see a tab for LANGUAGES.
Here I again guess that you have the "Instal files for complex script and right-to-left languages" box ticked.
Turn this off.
Not sure if you have to restart Archicad or maybe even the whole machine for this to take effect.
Hi Barry,
I don't know how to thank you, your suggestion was totally right. That solved my problem and explained how it occured. We (me and my 5 more colleagues) thank you very much.
Baran wrote:
Hi Barry,
Glad to help
I've had so much assistance from this forum in the past it's nice to give a little back.
