A new Keyboard you propably LOVE
I just found out this OLED keyboard
http://www.artlebedev.com/portfolio/optimus/
It might be alittle bit pricy, but imagine of the possibilities.
Load an archicad configuration (perhaps make 2 for different cases) and then no more shortcuts to remember , everything at your fingers.
9 Replies 9
Dwight
I'm betting on this technology:
http://www.alpern.org/weblog/stories/2003/01/09/projectionKeyboards.html
Actually tried one at siggraph - unbelieveable.
Here you go: $200.
http://www.virtual-laser-keyboard.com/
I don't think they are programmable as the oled one is, but what is stopping them?
Dwight Atkinson
I have heard they dont work under all light conditions.
The OLED is very nice looking by the way.
I imagine using one loaded with shortcuts i usually use.
Great boost in productivity.
I have seen posts talking about mouses with 5-6 button... programmable.
Here we can have all buttons programmable AND with a visual icon in case we forget smthg!!
D**n... i want it
Petros Ioannou
What a Keyboard!!!!!!
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
omg i want it....
This is the keyboard I have dreamt of for years. I started typing on a Dvorak layout (sooo much faster) and have been frustrated that it's so hard to do with a computer (there are no command and option modifiers on an Olivetti).
Finally someone is doing it.
I'm going to get one!!! (When - and if - they start shipping.)
I havent seen a DVORAK keyboard in ages... brings back memories from my primary school computer class
Dwight
SWITCH TO DVORAK NOW:
http://www.mwbrooks.com/dvorak/support.html
For Mac it is built in.....
Dwight Atkinson
The problem is that I have become so accustomed to the QWERTY command keys. I need key caps with two letters on them or ones that change when I press the modifier. (I never did learn to touch type - I still look at the keys occasionally).
My original Dvorak keyboard was an Olivetti portable which I converted. Moving the key caps around was simple. Removing and resoldering all the typeheads was more than a bit tricky. But it didn't have any command, option/alt, or ctrl keys to worry about.
Dwight
I understand that you can print the layout......
The article says it only takes a month to switch over, but that really good QWERTY typists (over 60wpm and 400 hp) find it the most difficult. Sort of like leaving AutoCAD.....
What is wpm in metric?
Dwight Atkinson
