Installation & update
AC 12 3D Screen Tearing
Hello everybody,
I have recently decided to upgrade my OS to Windows 7 Professional x64. The problem I'm having now is the tearing effect i get when navigating in 3D. I tried using the internal engine, but the problem stays there. My video card is an Asus Nvidia GTX 460. CPU - Intel Core i5 (3,60 GHz). 8 GB of RAM.
Has anyone any idea about what might be causing this?
Thank you in advance,
Adrian Tudoreanu
P.S.: I also tried different drivers for the video card, disabled 'Vertical Sync', tried running AC in compatibility mode for XP (with disabled 'Desktop Composition', disabled 'Visual Themes' and disabled "Display Scaling') - with no luck.
Did you find a solution to your problem? Im also experiencing this screen tearing with a GTX 480 on win 7 and Archicad 12. 12 is supposed to be compatible with win 7 so im ruling that out. Must be the GPU. I have the latest drivers installed. Don't really want to role back to old drivers as that will impact my other programs. Not sure quite what to do.
Unfortunately no. Meanwhile I have upgraded to AC14 and that problem is gone.
