Installation & update
AC 15 Glitch? After Hotfix II..cannot use 3d window
without massive jumps. Window freezes and I have to hit ESC to see where the view has ended. Also, this glitch seems to happen ONLY after I have modified an already existing model. Any suggesttons? PC education version of AC15. NO PROBLEMS until fix.
Update...glitch is spreading. Only seems to happen when I use mouse to navigate 3d window. AND seems NOT to happen when I use hidden line 3d and only in shaded drawing. This has NEVER happened in my ten plus years of using archicad. Baffled.
Video card?
ATI Radeon 3600 se...same as before...only difference is the Hotfix applied...also I add a new object/wall to model and the glitch begins. I am thinking of uninstalling and then reinstalling...
