AC 16 takes forever to load pls help!
AC 16, with 4010
win 7 pro 64 bit sp1
codemeter
Archicad now takes about 20 - 30 min to load a file.
Seeking direction optimizing settings-
cmstick is on port 22350, how do i tell Archicad to use that port and not spend all day scanning??
Are there registry settings for this?
I reinstalled from disc, worked for a while now back to error 230, no valid licence key found...
I also reverted to the version of java that came with my ac16 install.
REALLY appreciate any helpful input
Thanks a million.
Andrew
3 Replies 3
A 20-30 minute delay is almost surely a problem with a failing disk drive and not an issue with AC or your codemeter key. How old is your computer? Have you run full disk diagnostics on it?
https://technet.microsoft.com/en-us/library/ee872425.aspx
I've not run AC under Windows since I wrote this article on limiting the ports that are scanned for the protection key... and this article refers to the old WibuKey vs the current CodeMeter driver, so I have no idea if there is a similar interface to limit codemeter scanning. (It isn't AC that scans ports, but the codemeter driver.)
http://helpcenter.graphisoft.com/troubleshooting/licensing/wibukey-troubleshooting/limitation-of-por...
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
bought the computer new in 2014
I took a chance and edited the registry and now from dbl click to open is under 20 sec!
Actions taken:
HKEY_CURRENT_USER\Software\Graphisoft\ArchiCAD 64 16.0.0 USA R1 RefreshDiscoveryInfoTimeInMSec changed value from 180000 to 1000
HKEY_CURRENT_USER\Software\Graphisoft\ArchiCAD 64 16.0.0 USA R1\MEP Modeller RoutingErrorsDialogVisible changed value from 1 to 0.
I hope this helps someone in the position ive been in for 2 missed work days...
