Robby
AC 22 crashing with DET_stud 22
Lately, AC 22 has been crashing on me whenever I try to detail using the Object DET_stud 22 located in the US library, Detailer Library 22 >Wood 22>Wood Frame 22
I have been working around it by copying the object from a previous drawing.....no crash then....
Anyone else having this problem?
Thanks....
Rob Marelli
AC 28.1
MacBook Pro (2023) M3 Max -48 Gb RAM - Sequoia 15.3.2
10 Replies 10
Robby
dkovacs wrote:
Hello Robby,
Sorry for the late reply. I am not sure whether it is the same issue as what Ralph found, but your BugID points to an error that we plan to fix in our next regular update of ARCHICAD 22 (build 50xx).
You should find the fix in the Release note as fix #254073. If after the update you will still get the crashes, please report it to your local support with this number.
Thanks,
Thank you Daniel. I have installed the update and so far have not had any crashes- seems to work well now. Thanks !
Rob Marelli
AC 28.1
