AC Crashes
Bob Moore
My AC 27 has crashed 3 times today. Every time I try to close a tab it crashes and sends a message to Graphisoft.
It always crashes when I edit text with the caps lock on which is a real pain to work around and they don't seem to want to fit it.  Now this.
Glad to see SSA membership is going up by nearly 20% this year.
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
2 ACCEPTED SOLUTIONS
The release notes for the 27.2.0 Update Preview indicate that this cap lock crash is solved in that build.  Have you tried installing that @Bob Moore and @Aaron Bourgoin ?
https://community.graphisoft.com/t5/Graphisoft-Insights/Archicad-27-2-0-Update-Preview-release/ba-p/...
UPDATE:  The release version of 27.2.0 was announced on 26 March:
https://community.graphisoft.com/t5/Graphisoft-Insights/Archicad-27-2-0-Update-release/ba-p/592019
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
@Bob Moore wrote:
Now if I can figure out why it crashed when I closed the tabs.
I know it is a pain, but whenever there is a crash, take note of the bug report number.
Send the bug report off with as much extra information as you can.
Then follow up with a call or e-mail to your local Archicad support and quote that number asking them to investigate what the cause was.
7 REPLIES 7
Aaron Bourgoin
it's very frustrating, but the fix for this until the hot fix is to disable your cap-lock key.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.27 Mac
MacOS Tahoe 26.2
We don't install the Previews on our workstations. Too much work for the risk and the inevitability of having to do it again for the real build.
Rhino 8.27 Mac
MacOS Tahoe 26.2
I guess it's a trade-off, as always, Aaron.  I have yet to see a Preview that has a serious issue ... and if you read the release notes, an incredible number of things are fixed in the Preview which has been out for over a month ... approaching 2 months.  Comparing the small amount of time to install the release build  later while saving time not dealing with fixed bugs and crashes... I've always gone for the Preview builds upon release.  (Particularly in the last few years where there is a remarkably long delay between the availability of the Preview and the final release.)
Hi Karl, if it were just me, it would be installed. but we've got 40 plus workstations to worry about.
Rhino 8.27 Mac
MacOS Tahoe 26.2
I have the update, and you are correct it is fixed. I just got used to leaving the caps lock on and holding the shift key.
Thanks, you've made my day and made me more efficient on that issue. Now if I can figure out why it crashed when I closed the tabs.
It hasn't done it since those 3 times earlier.
Thanks
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
