Scott Bulmer
AC10 DWG translator & images
Attempted several times to publish to a DWG file that includes a PDF sketch image of a proposed framing plan. Tried all the various ways to export the file, but the image never comes across. The balance of the drawing is fine.
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
2 Replies 2
I think AutoCAD doesn't support placing PDFs into DWG files, interesting to see how AC 10 can solve this..
You may need to convert the PDF to a TIFF or other bitmap that DWG supports. You can do this with Photoshop.
