ā2009-01-11 09:58 PM
ā2009-01-12 10:06 PM
ā2009-01-13 03:45 AM
henrypootel wrote:
go into your Work Environment settings(from the Options menu), and go to the 'Advanced Redraw Options' page. Check that your 'Model Display in 2D Navigation' is set to simplified, and that 2D Antialiasing it turned off.
The first option should speed things up a bit and make the model not show True Line Weights when you pan/zoom, and the second option should make things a lot faster.
ā2009-01-13 01:47 PM
ā2009-01-13 05:51 PM
gpowless wrote:I did that a coupled of days ago, and just did it again now, 5.9 in all
If you built or upgraded your computer hardware / software combination you might have to get Vista to upgrade the Windows Experience Index.
Go to the Welcome Centre (can be found in Control Panel)
View Computer Details
Beside "Rating" select Windows Experience Index
Select "Update My Score"
Let us know if that works.....
ā2009-01-23 08:59 PM
