AC15 Lion text edit
Cameldesign
Multi-line text edit will show only part of text string.
If I unwrap text then re-wrap it it will show complete string.
Is this part of the Lion text conundrum?
AC 27 US
Mac mini M1
Mac OS X 14.1.2
11 REPLIES 11
I'm getting the same thing.
Ralph Wessel
Mentor
Not seeing the problem here (AC15 3267 on Mac OS 10.7.2).
Ralph Wessel BArch
Software Engineer Speckle Systems
genarch
Same problem here, it's a pain in the neck. I've tried changing the visibility of the scroll bars (System Preferences > General), but it didn't make a difference.
MacOS Sonoma
AC27&26, Artlantis 2020, TwinMotion
Mac Studio M2 Max 2024
Stephen Dolbee
I get it even with single line text. Parts of it disappear while typing, but always is correct once it is clicked in place
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Multiline is fine for me on 10.7.2, but single line is absolutely bizarre: simply double click with the text tool and start typing - as I type, worse, all prior text disappears, then reappears. Sometimes, just the last word I typed shows up until I press the spacebar - then the rest of the text appears.
Annoying, but not a deal-breaker.
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Ralph Wessel
Mentor
You indicate you're using Leopard on a PPC Mac. If so, it's a general bug rather than a Lion issue. I hadn't noticed the single line issue - it seems to happen only periodically, and I hadn't really been looking that closely at individual words while typing.
Ralph Wessel BArch
genarch
My profile also said I was using ArchiCAD 12. I'm now using AC 15 on Mac OS 10.7.2 from an Intel iMac. Profile updated.
MacOS Sonoma
I found out that when I put a space at the end of the text line and backspace once it does not give me any problems with the text. Not great but it works for now.
good work around! hopefully they fix this asap, very frustrating!
