AC17-HF02 Extremely Slow with 2 Sessions Open
Eduardo Rolon
After installing Hotfix 02 if I have my Model file open and my Layout File open switching between causes then one in the background to beachball for about 5-10 min.
Not happy. The only workaround is to have only one session open which defeats the purpose of verifying and fixing drawings.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
4 REPLIES 4
Csaba Kezer
Hi Eduardo,
Thanks for posting this.
We are interested to see why this is happening. I have sent you a private message with a request for the files you have problem with.
Best regards,
Csaba
Csaba KƩzƩr
VP, Global Customer Support
Eduardo Rolon
Uploading the files.
AC29 US/INT -> AC08
another Moderator
Csaba Kezer
I have checked the files. I couldn't replicate this freeze on my mac, but it seems to me that this is the issue that you are experiencing:
http://www.archicadwiki.com/Troubleshooting/MultipleInstancesSlowdown
So what you could try is to temporarily change the file format in all the publisher sets to pdf from dwg to see if it resolves the issue.
(Obviously disabling IPC connection in the Preferences would not let the two instances communicate with each other)
We plan to fix this problem with a Hotfix in AC 17.
Csaba KƩzƩr
Eduardo Rolon
Will try the fix and let you know. It might be coincidence but there was no problem prior to HF02.
AC29 US/INT -> AC08
another Moderator
