Scott Bulmer
AC9 Library Special Edition
We are unable to find a setting to control where the adjustable hotspots locate themselves for windows and doors in the new Special Edition library. The current locations make manipulation difficult. Any advice would be greatly appreciated.
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
14 Replies 14
Scott Bulmer
Graphisoft wrote:
Ok, I also get those polygon degenerated errors. I have reported this to R&D and will let you know as soon as I hear.
Scott Bulmer
Door thresholds do not show in AC9 or plot when option is selected. Note; display options is set to show doors.
Link
Are you using these doors in single skin composite walls by any chance?
Link.
Scott Bulmer
Hey Link,
If I understand you correctly, yes. The walls are simply set to 'solid fill' without any additional composite lines or fills. The doors are set using the new setting to 'stud wall.'
Thanks,
S
Scott Bulmer
Graphisoft wrote:
Hi Scott,
R&D has reproduced this error and entered it into their errors db.
Thanks for reporting.
