Installation & update
Add-Ons in AC 26 not showing in the menues
Tomcad
I see that this seems to be an issue for at least 8 month now but Graphisoft does not make any efforts to solve this problem. This is even more frustating since commands, that used to be normally implemented in AC now only are available through add-ons (i.e. importing .obj, .dwg, .dxf etc as objects).
11 REPLIES 11
I'll check. Good idea.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
On second thought, add-ons originally not in the WE should add their menu items to the menu defined in their code — like a default menu position. For example, PolyCount installs its menu item in the Palettes menu or Check Duplicates in the Options menu.
The menu positions you saw in earlier  AC versions were overridden in the WE settings manually to place those add-ons into more logical places — taking precedence over the default positions defined by the add-ons' code.
So, the interesting question is: why don't the add-ons appear after installation? If those commands are not part of the WE, they should appear automatically... unless there's another bug somewhere 😞
