David Bearss
Apple abandons quicktime
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
FYI:
ARCHICAD 18 and newer do not install or use QuickTime:
http://helpcenter.graphisoft.com/technotes/setup/archicad-installation/quick-time/
Now the only question is what people using older versions should do? As far as I remember, if QuickTime is required for ARCHICAD 17 and older and if it is not installed will not start. So I suppose this is not an option for those people.
Csaba Kezer
Hi guys,
AC 15-17 can survive without QuickTime, only v14 and older cannot start up without it being installed. See more information in the updated Help Center article.
Best regards,
Csaba
Csaba Kézér
VP, Global Customer Support
