‎2009-01-20
08:41 PM
- last edited on
‎2024-04-26
11:22 AM
by
Aruzhan Ilaikova
‎2009-01-20 11:26 PM
‎2009-01-24 10:28 AM
bigE wrote:If it were XP 32, it would work. Amyuni that is provided with 10 is only 32 bit.
I have looked through the forums and the wiki but I havent got a specific answer so I thought I would post.
I am installing ArchiCAD 10 on a Windows XP 64-bit machine.
‎2009-01-26 07:12 PM
‎2009-01-26 09:38 PM
‎2009-01-26 09:52 PM
‎2009-01-26 10:37 PM
‎2009-01-27 11:59 AM
bigE wrote:Duplicate the Publisher set, specify Print instead of SaveAs, set PDF printer. Done.
The project is already setup using the save-as and is quite large. Was trying to not have to redo any work.
bigE wrote:Whoa ... if you do this, good luck! If you do NOT initiate changes to the habits all the time, you are faced with a nightmare. Change is not the problem, documenting it is, as is the followup. A lot of work to do.
Also our user base uses the save-as method and always has.
Theres no difference, just in a multiple user environment change usually equals problems. If I can quelch any possible changes to habits and project setup it would save a bunch of headaches.
‎2010-07-15 09:33 PM
Djordje wrote:Unless there's something I'm missing, this results in being prompted as to where to save the resulting PDF for every sheet. This is extremely time consuming on layouts with more than 5 or so sheets.
