Installation & update
Powerful computer for mostly 2D work, preferably for long term
K_Gergely
Hi everyone,
I want to build a stable, fast and silent computer which can be kept up-to-date for long term (say, 5-10 years), and would like to ask for your advice.
I make technical detail drawings in ArchiCAD (currently in ArchiCAD 27), so I mostly work in 2D placing external DWGs as references.
The main components of the planned configuration are:
CPU:  Intel Core i9-14900KS 3.20GHz
Board:  Z790 chip (e.g. Gigabyte Z790 Eagle AX (rev. 1.0) )
VGA: Sapphire 11335-04-20G Radeon RX 7700 XT 12GB GDDR6 PULSE PCIE
RAM: Kingston Fury 64GB Beast EXPO DDR5 6000MHz CL30 KIT
SSD: WD 1TB Black SN850X with Heatsink M.2 PCIe M.2 2280
OS: MS Windows 11 Pro 64bit
Other planned components:
Power supply: Corsair RM850x 850W PCIe5
CPU cooler: Deepcool AK620 Zero Dark
Case: Silverstone Seta D1
What do you think - will this computer be powerful and stable enough to run ArchiCAD 27, or newer versions (28-29) fast?
Perhaps it seems to be a bit 'overkill' for 2D work, but I want to build it for long term, I want to use two 4K monitors, and DWGs placed in PLNs can put a surprisingly high load on the system (this is my own experience).
Can anybody see a bottleneck in the planned configuration, which should be eliminated?
Is anybody aware of any stability / incompatibility issues?
Any advice, personal experience would be highly appreciated.
Thanks in advance,
Gergely
Gergely
2 REPLIES 2
Yes.
If you check the following web page:
https://www.graphisoft.com/us/resources-and-support/system-requirements
you will see that your planned configuration meets even the High-end requirements.
So, you should be fine for at least 4 or 5 years with this config.
I have an AMD config; I did not have any compatibility issues with that. Maybe someone else can speak about their i9 config.
Gerry Leonor
make sure to also update the firmware on your BIOS if you decide to stick with the 14900.
AC25 | Win11 | 64Gb RAM | Intel i7 13700F | RTX 4070 Ti
https://discord.gg/XGHjyvutt8
