Aaron Bourgoin
ArchiCAD 11 Hotfix 1259 Issues
Has anyone had installation issues with the ArchiCAD 11 Hotfix 1259? A client of mine claims ArchiCAD won't start after he applies the patch.
MacIntel version.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
3 Replies 3
Erika Epstein
Works fine here both WIN XP and mactel.
Was 11 the one that had a patch that must be installed in sequence (or something unique)? Perhaps they missed that step?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
David Maudlin
Aaron:
I had a similar problem with the PPC version, then saw that I had renamed the ArchiCAD application from "ArchiCAD" to "ArchiCAD 11". My fix was to reinstall the original from the DVD, then apply the latest hotfix (no need to fool with the earlier hotfixes), this worked fine. He should move the old ArchiCAD 11 folder out of the Applications folder before doing the fresh install, as there may be items there he will want to move into the fresh installation (Add-Ons, etc). My recollection is that renaming the application would cause these types of issues, I probably renamed this one because I thought there would be no more hotfixes to 11.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Aaron Bourgoin
Thanks all. So far neither of these seem to be the issue. We'll keep digging.
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
