2023-10-12 02:01 AM
I downloaded and installed ArchiCAD 27 yesterday and started my first project w/it today (been using ArchiCAD since v6.0). I started with a clean AC27 template file and imported pen sets, layers etc... from an AC26 project via Attribute Manager. The project is so far, is limited to 2D civil survey information that I copy pasted onto a story. I'm finding the basic performance inside AC27 to be so bad, it's unusable - panning, zooming, basic editing, adding dimensions etc... every mouse movement and click has a patience-testing long delay. There HAS to be something I've done to make it this way, I CAN NOT imagine that Graphisoft released AC27 knowing the performance was this slow.
What can I do to reset or troubleshoot this? I've quit and restarted ArchiCAD a few times and it's not better. There HAS to be something I'm doing wrong, I just don't know what it might be...
I don't know if my signature lists my hardware and if it does, it's probably outdated since I haven't posted here in a long while. I have a 16" MacBook Pro w/Apple M1 Max chip, 64GB Ram, macOS Monterey v12.7 and a 27" LG HDR 4K external monitor.
Thanks,
Tom
2023-11-15 07:08 AM
Hi Tom, maybe the project is too far away from point zero? You mentioned working with 2D civil survey information.
2023-12-23 01:26 PM
I have the same Problems on my Windows PC (Dell XPS 17 9700) zooming and panning is a pain compared to older versions... Especially using the Eyedropper Tool kills the whole application.
2023-12-23 07:41 PM
For Windows this transition from opengl to directx improved the appereance but decreased the performance. At least this is my feeling...
2024-02-16 03:15 PM
Do you still have the problem with Eyedropper tool or have you manage to find out what the problem is?
