‎2007-06-11
08:35 PM
‎2024-07-09
08:36 AM
Aruzhan Ilaikova
‎2007-06-21 10:24 PM
‎2007-06-21 10:39 PM
‎2007-06-21 11:06 PM
Dwight wrote:WOW you guys are a bit rough on a newbie!
Swell. Ignore warnings, proceed at peril.
That object is calling a macro. Something is corrupted.
It might be the object should be replaced from a clean library.
It might be an inadvertent bad setting in the object.
If you were a mechanic and this were an old car, you'd systematically test the possibilities by locking out what the problem might be.
It seems like a window trim. Try to do a 3D without showing windows and see.
This is done by using the Filter Elements in 3D command that provides a list of categories to not view.
‎2007-06-22 04:09 PM
‎2007-06-22 04:26 PM
‎2007-06-22 11:05 PM
‎2007-06-22 11:33 PM
‎2007-06-23 12:45 PM
sham wrote:"Converting" means using the instructions in the object's 3D script (program) to produce 2D/3D geometry. Most ArchiCAD library parts are dynamic, producing 2D/3D geometry on demand rather than storing a pre-defined shape. If there is a fault in the object's programming, it will fail to 'convert' to a 2D/3D image. The warning message provides you with some clue as to why parts of your project model are not appearing in 3D. Diagnosing the actual cause is another matter
Does anyone have an idea about window units not being "converted" what does that mean?
‎2007-06-23 01:17 PM
