ā2024-03-29 08:23 AM
ArchiCAD is sending me a bug report, I had to uninstall all and now I can install the update as itās keep saying that I can not save the file in the selected files, so I can not install the update Archicad 27.2.0, Iām working on a teamwork and now I donāt know how to get access to the project if I go to a newer version than my team.
also, after the installation is still showing bug report notifications! Does anyone now what should I do?
Thanks.
Operating system used: Windows 27.0.0.5003
ā2024-03-29 03:47 PM
This does not make sense.
Download the base Archicad (3001) installer and install it. from here
Then download the update 27.2.0 and install it. No need to open AC prior.
The rest of your team will need to update to the latest updated version
another Moderator
ā2024-03-29 04:02 PM
Thank you Eduardo, I had downloaded the 27.2.0 but is not letting me save it, itās keep saying that āno suitable Archicad 27 was found in the selected folder. Please select another Archicad 27 folderā and i tried to do it and still showing that message
ā2024-03-29 04:25 PM - edited ā2024-03-29 04:29 PM
If you removed your previous installation you need to install Archicad first then install the update.
another Moderator
