Aussie John
ArchiCAD v10 and Leopard OS macs
On a cursory glance it appears archiCADv10 and Leopard (intel) works. What if anything is broken with this combination?
Thanks
Cheers John
[/size]
7 Replies 7
Chazz
I've not had any issue with this combo and use it frequently.
I mean I'm not saying you should not be prepared for problems but were you expecting something particularly awful to happen?
Nattering nabob of negativism
It is heaven !
Except ArchiCAD is still stuck with one processor when doing elevations, sections, and sketch. At least Lightworks uses all processors.
Aussie John
Chazz I note you have ArchiCAD11 in your signature I am talking about v10
Cheers John
[/size]
Chazz
Hun, I mostly use AC 11 but have existing, almost done projects in AC10 that I run under 10.5.2 without issue. I know lots of folks who run AC 7 under Leopard. It is not an a problem (however a friend recently showed me that the PlotMaker window cannot expand to fill his 30" monitor, it only goes about half way).
Please, worry about the US democratic primary, or global warming or the baggage retrieval sytem they've got at Heathrow or something else but don't worry about this.
I can tell u that i have a problem with one thing so far with AC10 on Leopard which i dont have with AC11.
http://archicad-talk.graphisoft.com/viewtopic.php?p=114507#114507
Chazz
Yes but I'll bet you'd have the same problem with this under OS 10.4. This sounds like an issue with AC 10, not AC10 and Leopard.
Thats weird cause ive tried searching for answers and cant find any and many i bet used it on 10.4...
