Archicad 12, windows vista ultimate --> Cant view in 3D!!
I recently purchased an HP with 4GB ram and 250 GB memory, i put windows vista ultimate on it hoping that it would keep me away from the problems when downloading archicad 12, and everything was going well until i tried to view in 3D and it renders for about five minutes, and then the drawing space is just gray, and you cant see anything, but if i click where the building "should be" it highlights (the green and nodes) and thats it. any suggestions???? anyone else going through this? please help!!! thankyou!!
2 Replies 2
3D depends entirely on your graphics adapter, which you didn't give specs for... Make sure you have downloaded the most up-to-date display driver for it.
...and put your system specs in your signature. It makes it much easier all around.
