Archicad 15 on Windows 10
Hello there,
I have had to purchase a new computer. Unfortunately the only Archicad license I own is version 15. However I am having issues installing on the new computer. Can you help please.
Thanks.
2 Replies 2
From memory I think you will need to install the Java environment that is on the install DVD of ARCHICAD. Then you can try running the installer again.
Later Java versions in later Windows operating systems may not be compatible with that earlier ARCHICAD installer.
Yes that worked! Thank you very much!
