Archicad 20 Extremely slow after latest update
I wonder if any one is finding this to be true , Archicad seems very slow after the latest Mac os update and the Archicad. It is extremely frustrating. When I use Pan the whole screen goes grey. If any one can shed a light I'll appreciate it.
8 Replies 8
Katalin Borszeki
HI!
There could be several issues causing the slowness.
1. Slow 2D could result from special mouse settings, please find a workaround in this troubleshooting article:
https://helpcenter.graphisoft.com/troubleshooting/performance/archicad-20-performance-troubleshootin...
2. The slowness could be caused by 2D Hardware acceleration:
The workaround here is:
- change the settings in Work Environment --> Advanced Redraw Options --> 2D Drawing Hardware Acceleration --> set it to Full
- change the settings in Work Environment --> Model Rebuild Options --> Background Update --> Disabled
Also please install the latest update for ARCHICAD: 6005
Best,
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
I too am totally frustrated with both 20 and 21. I am spending 10 minutes every hour watching a circle turn around, meaning efficiency is completely gone as too has the value in the software. Please provide some advice on rectifying the issues.
Have you tried the above suggestions?
What are your machine specs?
Eduardo Rolon
• Make sure to rule out possible hardware problems. A failing HD might cause slow downs as would bad RAM.
• File size might be an issue since you can add enough extra objects to paralyze any type of software. You can rule out if the slowdowns also happen with a new file.
10 mins with a spinning beach ball is not normal.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Make sure you have a decent amount of free space on your main hard drive as well.
Hi
We have the same issue.
Archicad 20 and 21 runs as it should for about 10 min, then it freezes with the spinning ball for about 1-2 mins, and then it starts working again. This behavior repeats about every 10 mins.
It doesn't matter if we work online on BIMCloud with ongoing projects or offline with a new project, same problem occurs.
We are 4 people that have the same problem, we all work on mac and have the latest Archicad update.
I have tested both Yosemite and Sierra, same issue.
This makes it very hard for us to work, and it have to be resolved asap!
Anyone have any suggestions other than specified above?? Tried them, but they are not working unfortunately.
Thanks
I have been working in archicad for over 7 years now and what I am experiencing is a program that is slower and more cluttered with every new release. In normal everyday use I have no use for all of the new features they add and only thing our entire office(about 50 people) wish for is a more streamlined and faster program. I would severly cut down on all the clutter in the program and take a serious look at the background updating progresses. i have myself sent videos to graphisoft where i film myself going back and forth between windows in archiad without doing anything and with absolutely identical setup for the windows yet still have to wait for blue circle for over a minute each time.
As some people mention this is especially bad in the 20 and 21 release. If there is not serious action taken to start moving in a new direction I think the number of users will plummet.
-Martin
Hi Martineide , did you resolved the problem with 2D slow in Archicad:?
We are noticed that Archicad when is running on Apple Cinema 30(2560x1600) (instead od 27 IIyama 1920x1080) is running a lot worst, and we been usein Geforce GTX 970 4GB on Mac Pro 3.1 with 8x 2.8GHx Xeon.
It is wird, as as far I remember , newer before on Archicad we been workin as ver 8 , 9 , 10, 11 even 14, on much worst configuration, been working very very fast (on 2D)
Regards
John
