2024 Technology Preview Program
Installation & update
Archicad 21 Navigator Project Map Crashing
I have only experienced this issue recently.
I will be changing something in the Project map in the navigator and it will freeze and then go blank (see image attached)
It will be fixed if i close the navigator and open it again but if i do something like I was trying to do, e.g. renaming an interior elevation, it will do the change but not show it, freeze, then go blank again.
I havent had the issue using the organizer but that is more limited to changed and more for organizing.
Any help would be appreciated. Maybe I need to update too.
Thanks.
After updating my archicad it seems to have fixed the issue. If i encounter any more issues ill reply again.
1 REPLY 1
