Installation & update
SOLVED!
Archicad 22 download link
Aht
Hi.
If someone try download Archicad 22 with the link provided in archicad downloads, they seems have 160mb insted 1.9 GB. The problem Its only in this version. Can someane give me a correct link for download off archicad 22.
Thanks in advance.
2 ACCEPTED SOLUTIONS
Solution
I just tried it.
The screen shows it should be a 1.9GB file.
But when you download it , it is only a 160MB file.
I'm not sure what actually downloads as I get this when I try to run it..
I also tried the AUS version - same thing - 88MB file.
UKI version seemed to be fine.
So some of the links are to incorrect files.
So if I bring @Noemi Balogh into this conversation, maybe she can pass it on to the appropriate person to have the links fixed please.
Solution
UPDATE: We fixed the downloads according to your reports.
Noémi Balogh
Community Expert, Admin
5 REPLIES 5
Is this the link you used?
https://graphisoft.com/resources-and-support/downloads?section=product&localization=INT&product=arch...
You don't say what language or Operating System you want so I couldn't check the specific link.
Aht
Yes, the link is that (INT language), and OS is W7 x64. Thanks.
Solution
I just tried it.
Noemi Balogh
Dear All,
Thank you for your report. We are working on the fix now. I'll update you here once the downloads are back on track.
Kind regards,
N.
Noémi Balogh
Solution
Noémi Balogh
