'Archicad 22 would like to access your photos' [?]
As I was browsing a .pln saved as from a .pla created somewhere else on a Mac OS 10.14 Mojave I got a pop-up 'Archicad 22 would like to access your photos'. I declined in panic and forgot to screenshot, but I am fairly sure that was the wording.
What is that?
7 Replies 7
Erwin Edel
You probably have placed some linked files from this folder in your project or linked it as a project library.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
I did not modify the file, which came from elsewhere, other than saving from bimserver to pla to pln.
The wording I remember is 'your photos', not such and such folder, and not 'your Photos [the application, that is] folder' (I might be wrong, but I am convinced).
On Drawing Manager there are a lot of images and PDFs with paths to Desktop and Downloads folders from several local users, but of course I am not any of those local users.
DGSketcher
Legend
It seems to be a "bug" between Mojave & AC22. I get it randomly typically after a cold boot and I assume there is no need for the photo access so I just select the decline option. When AC22 was first released I think it even asked to access the microphone. I doubt it is malicious.
Stress Co_
I've had it ask for access to my contacts as well.
I'm on Mojave too.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Contacts is a 'known issue' in Graphisoft reference material. Photos was a surprise to me. Thanks for the replies.
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
As you said, there is a known compatibility issue between macOS 10.14 and ARCHICAD, that was fixed in AC22 40xx (and AC21 70xx):
https://helpcenter.graphisoft.com/knowledgebase/85297/
I think this must be caused by the same thing. If you install the latest update, you should not receive this prompt anymore.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
[I got my 'photos' request in 22 5009. Also the known 'Contacts', before that.]
