Installation & update
SOLVED!
Archicad 24 intermitten crashing
ericw
Dear Archicad guru
I am a total noob and hope anyone can advice.
Recently, I experienced my A24 keeps crashing for no reason and I am trying to figure out what is the issue. I understand it creates a bug-report and was able to extract it as txt form. Below are the error I found , if you do not mind
I saw the word' failed' and was confused. I noticed it was trying to locate P drive, which I do not have.  I am unsure whether it was trying to locate the file.
Appreciate any input.
Thanks
1 ACCEPTED SOLUTION
Solution
Been running AC24 for about 6 months last year and this year with the AUS 7000 build on a windows 10 machine never crashed so far.
Might have to go to tech support if you can’t get a AC Guru to help you out here ?
AC8.1 - AC28 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia
3 REPLIES 3
mthd
Ace
Hi, please add your system info on your profile and your build number so someone can help you out. You may need to download the latest build of your version of Archicad ?
ericw
Apologies.
I am using Dell Precision 5820
 - Intel Xeon W-2123
-  64 GB RAM
- 1 x 1 TB Nvme storage
- NVIDIA Geforce RTX 4070 12 GB display adapter
   ( this card was installed to test. Previously using NVIDIA Quadro P2000, 5GB but the result was worse )
the Archicad 24 has updated to build 7000
I cant find any more build from it since the last update.
thanks
Eric
Solution
