Installation & update
SOLVED!
Archicad 25 AUS Download for Mac
mthd
Hi, I am looking to a link to Archicad 25 AUS for Mac to test it out if possible ?
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
1 ACCEPTED SOLUTION
Solution
@mthd wrote:
I found that one yesterday but I couldn’t get directly to AC25 AUS for Mac ?
Just adjust the settings to any language, program, version or platform you want.
AUS Mac 25 is there.
9 REPLIES 9
Lee Hankins
You’ll only be able to get a copy of Archicad 26 for evaluation purposes. There is a free trial available.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
mthd
Thanks Lee, I did download a Windows version of AC25 for evaluation a few months ago but that PC is over 13 years old now. I takes quite a while to fire up. I am seriously considering upgrading to 26 before the end of May. I want to see how good Redshift is at Rendering but I think I will need 26 anyway to test that out. From what I read Redshift was only a technology preview in AC25 and only available for GS forward clients as I understand.
Lee Hankins
That’s right. I think Redshift is still only available for Forward customers but if you get a license of AC26 now I believe it will come with a year of Forward and access to those features.
Lee Hankins
macOS Tahoe (26.0)
DGSketcher
Legend
@mthd If Redshift is a key feature for you then check the technical requirements. I bought a high spec Mac in 2019 not long before Redshift was added and it wouldn't work with it. It required an advanced graphics card at the time.
https://graphisoft.com/forward/redshift-for-archicad
All versions of Archicad back to 18 for all operating systems can be downloaded from the Graphisoft website.
https://graphisoft.com/resources-and-support/downloads?section=product&localization=INT&product=arch...
If you don't have a valid license, they will run in demo mode only.
I hope my Apple M1 Max can handle it with it being rated at 7.8TF and equivalent to an 8GB video card apparently ?
https://appleinsider.com/articles/21/10/19/m1-pro-and-m1-max-gpu-performance-versus-NVIDIA-and-amd
The system requirements seem to indicate that it will work but that’s why I have to test it out first for low rise residential work.
https://graphisoft.com/resources-and-support/system-requirements
Cheers Barry, thanks for the link.
I did however get your link for AC25 AUS windows a few months ago but my windows machine only has a 2MB video card in it. Not able to handle Redshift.
Solution
My Apple iPad mini 2 is to blame because it’s IOS is still at 12 something. A 2013 model and so it needs upgrading but they will not let it go above IOS 12 at present.
Found it on my Mac.
Thanks again.
Edit: Redshift current limitations for AC25 & AC26
https://help.graphisoft.com/AC/26/INT/_AC26_Help/140-3_Redshift/140-3_Redshift-2.htm#XREF_34278_Curr...
Are all these limitations still applicable in AC26 ?
