Installation & update
Archicad 25 License to be used on Previous version of Archicad
Dimas Aditya
Hi, can we use multiple Archicad version (21, 22, 23, 24, 25) within a single license? or do we need to have one license for each version?
Thanks
All earlier versions using the same protection key software can be run with a single license. See:
https://community.graphisoft.com/t5/Setup-License-articles/Licensing-Basics-ARCHICAD-License-Types-M...
4 REPLIES 4
Thank you very much Sir! god bless you
Hi. My Archicad 25 education serial number comes up invalid on Archicad 20. Any solution?
You can't use a 25 EDU for version 20 as discussed in this post.
https://community.graphisoft.com/t5/Setup-License-forum/Archicad-25-edu-license-on-Archicad-20/td-p/...
You will need to install version 25.
