Lee Hankins
Archicad 26 6003 (ARM) Update 4 doesn't launch after update
Just a heads up, we have upgraded all of our office machines to the Update 4 of Archicad 26 and so far none of the ARM/ Silicon based machines will launch Archicad 26. I have reported to local support.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
1 Solution
Tamas Gaspar
Hi @Lee Hankins , Hi All,
Thank you for reporting this. We have just released an article about this phenomenon and the solution for that:
https://community.graphisoft.com/t5/Graphisoft-Insights/Slow-Archicad-26-startup-after-installing-Up...
We will be keeping informing you and our local technical support teams about the news regarding to this issue.
Sorry for the inconvenience and thank you for the patience.
Regards,
Tamás
Tamás Gáspár
Manager, Partner Technical Support, Graphisoft
Go to post
11 Replies 11
DGSketcher
Legend
@Lee Hankins
Same problem on Intel. https://community.graphisoft.com/t5/Installation-update/AC26-6002-Upgrade-AC26-will-not-even-open/m-...
Only Graphisoft could take a working Preview version and screw it up for the Official release.  🙄
Lee Hankins
Well, as a slight update it did eventually open after between 12 and 15 minutes in our machines.
Lee Hankins
macOS Tahoe (26.0)
Really strange, Lee!  Eduardo and I reported in this other thread that 6003 works fine on our ARM Macs... he's on Sonoma and I'm on Ventura:
Tamas Gaspar
Regards,
Tamás
Tamás Gáspár
Lee Hankins
Thanks Tamas
Lee Hankins
macOS Tahoe (26.0)
jimmyp
this issue has just happened to me...in the middle of multiple deadlines. Just tried to manually delete the files you noted in your message above. Can't even find those files on my machine. They are not where you note they should be. I am running Ventura on an apple silicon and 26 will not open since the update that came out on the 14th. Need help!
PowerSquare Design
Denver, Colorado
Lee Hankins
Just launch Archicad 26 and wait. Be patient. It can take up to 15 minutes but once it has launched it will be fine next time. It will open.
Lee Hankins
macOS Tahoe (26.0)
DGSketcher
Legend
I fired up Activity Monitor after installing the 6002 update and there was listed [ Archicad 26 is not responding ], but at 14m:50s up pops the AC26 opening splash screen.
That's on a high spec 2019 iMac with i9 Intel CPU.
Lee Hankins
It does display as not responding which is annoying. It seems to take between 10 and 15 minutes no matter what specification of machine you have. Hopefully a fix will be issued soon although most people will have installed the update, come across the issue, launched Archicad and it will have fixed itself.
Lee Hankins
macOS Tahoe (26.0)
