2025-06-05 03:54 AM
I've noticed across multiple computers running Windows 11 Pro, that the window control buttons (minimize, restore, close) are missing from my interface. If i blindly click around in that vicinty, I can sometimes click on the right location, but the icons are missing. Anyone else having this glitch?
Operating system used: Windows 11 Pro
Solved! Go to Solution.
2025-06-05 04:07 AM
Seems to be a Windows 11 Dark Mode issue.
2025-06-05 04:07 AM
2025-06-05 04:12 AM
That did the trick! Thank you.
2 weeks ago
Do you mean close buttons in Tabs? If so, mine is also presenting a problem. The function close tab (with "x" on the corner of every tab) goes missing after closing one tab and other situations. So I cannot close the tabs. That in AC29, Mac, Tahoe.
2 weeks ago
No, that was an issue relating to the dark mode in Windows operating System.
Yours seems to be an issue with Tahoe?
Do other users on the same OS have the same issue?
I would also make a call to your local support to see what they say.
