Archicad 3d problems
I am having problems with my 3d displaying. As i click it, closes down the archicad. What can I do to fix this
Additional Info:
When I open up a project i previously did, it says i am missing some add-ons and list two
24 Replies 24
People might need more information to respond - like, Archicad version, Graphics card, is this something that has just started happening, or a new installation of AC?
it is ArchiCad 12, the problem started since I installed the software.
did u press zoom all? because sometimes the 3d window may pan to somewhere else
Its may be an OpenGL driver issue.
To test, do this: go to "3d Windows Settings" menu and change 3d Engine to "Internal Engine". Open a 3d window and if it doesn't crash then you may need to do update your graphics card driver (sometimes you may even have to go to an earlier version), check that the card is supported by Archicad and lastly turn down graphics card acceleration if the card is not fully compatible.
More info:
www.archicadwiki.com/Display%20Changes%20in%20ArchiCAD%2012?highlight=(OpenGL)
If all this fails just use the "Internal Engine"
the missing add-ons cadimage revision manager and cadimage update all
how do i update my graphics card driver, it worked with the adjustment that you suggested to me.
go to the official site of your video card
Thank you very much, problem solved
I am having a similar problem. My model is fine in 2d, but when I switch to a 3d view, nothing is visible. All the items are there, if I select all, they all highlight, but nothing displays in 3d. I've tried all my 3d views, none work. The model was working up until a few days ago, and now I cannot see any objects in 3d view. If I render them with Lightworks, they are there, and visible, but will not display in OpenGL. Help!
I'm using a OSX Leopard, Archicad 11, fully updated.
I've attached a quick screenshot.
