Your laptop is just fine, it has strong enough CPU, enough RAM, strong GPU, SSD system drive, so that is not the problem.
Probably one of your Rendering Settings is causing RAM usage to skyrocket and you run out of RAM.
One such candidate may be the Grass settings. Try to set it to lower, less dense, or turn it off altogether to see if that handles the issue.
