Archiforma 2.0 resolution query
How do I increase the resolution of the curve of this vertically extruded object in Archiforma (2.0). It would appear that resolution is not adjustable, am I missing something ? Is there another method within Archiforma to produce this object more easily ?
Justin
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Dear Justin,
formerly the curve resolution came from ArchiCAD but then I realized (thanks to some users like you) that it wasn't enough in certain case.
In the latest versions (please check at www.cigraph-store.com if you already have the newer one) you can select the ArchiForma Vertical Extrusion object, double-click in the ArchiCAD object tool icon and set the needed resolution in a dedicated object parameter.
If you have any other question, please don't hesitate to directly contact me.
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
