Installation & update
BIMcomponents Login
Miha_M
I can't login into the BIMcomponents website. After a Sign-in I don't get any error message, but I am still not signed in. I would like to get my registration code for activating the Archicad 23 link with the BIMcomponents site. What could be wrong? I am able to login into BIMX with my GraphisoftID, this forum (different login), but not BIMcomponents. I tried to reset the password, no change. I am using Chrome.
| Archicad 4.5 - 29
| HP Z840 | 2Ɨ E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
Miha_M
Solved. I tried another browser, Edge Chromium. Now it's working.
| Archicad 4.5 - 29
5 REPLIES 5
Miha_M
| Archicad 4.5 - 29
Miha_M
Update - I managed to connect Archicad 23 with the BIMcomponents Portal. But...
Searching with the library search tool I see a small yellow warning sign. Hovering with the cursor over this sign gives a message "A serious problem occured during communication with the BIMcomponents Portal. Try again later."
It seems like this connection needs an update for AC23.
| Archicad 4.5 - 29
Miha_M
I don't know if anything has been changed on the BIMcomponents Portal, as I didn't change anything on my side.
The Archicad 23 - BIMcomponents connection is working now.
| Archicad 4.5 - 29
Danmardan
Using a different (instal new) browser is not a good solution.... @GRAPHISOFT please fix it for mac OSX safari pls. Thanks, dm
Thank you very much for the report and I am very sorry for the experience!
As the screenshot suggests, in order to log in to BIMcomponent, you will need to allow 3rd-party cookies on your browser. Please follow this guide to unblock 3rd-party cookies on Safari.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
