BUG
Good evening, my archicad gives a bug every time I put the file in 3D, can anyone help me?
Thanks in advance.
Post has been moved.
Does this happen for every file or just the one?
If every file try using the vectorial engine in 3D rather than OpenGL.
If that works I would suspect something with your video card or drivers.
If no effect then I couldn't say.
If just the one file, I would suspect a corrupt element.
Turn just one or a few layers on at a time to try and work out where it is and what it might be.
Or you could try the 'Open & Repair' option when you got to FILE menu > Open.
Your best course of action though, is to take note of the bug number, send the report off and then contact your local support referencing the number.
