ā2007-02-09 08:44 PM
ā2007-02-09 09:59 PM
ā2007-02-10 03:09 AM
ā2007-02-10 03:46 AM
ā2007-02-10 03:55 AM
Mabe wrote:So plug in a Windows keyboard. With Boot Camp installed a MacPro is just a really good PC in a cool box (and cheaper than the equivalent Dell).
...and the difficulty of autocad users relearning the keyboard...
ā2007-02-10 03:05 PM
Matthew wrote:Exactly. Then the PC guys can even keep getting their worms and viruses as they are accustomed to. It must be said, if you have not booted windows on a mac and used it as if it were a PC (which it then is, in fact) - you really can't compare. You need to try this out. I can ask Apple to lend you a few workstations if BAR would be interested in checking this out on the floor...
ā2007-02-10 07:44 PM
andyro wrote:oooh.....this would be a great solution. I have tried every angle, this could be compelling. If you really think Apple would do this, we need to chat (or skype?)
ā2007-02-12 07:02 AM
ā2007-02-12 01:09 PM
Mark wrote:Why such a small Hard Drive?
Well.... if you end up going with a pc, this is what i am about to order, having 6 already very similar systems (the old Core 2s). I did a fair bit of research and found this to be the best "sweet spot" with cost v price. Of course everyone has a different opinion, particularly on the video card (being a workstation card) and amount of ram. But this video card kicks ar..se in 3d, and i can have several processor/ram demanding programs open with the dual core and 4gb of ram working without any slow down. Ram is also very good for rendering in programs outside of ArchiCAD. Note ArchiCAD can only use 2gb (currently) so don't bother going over this unless you plan to have other things open, which i think is almost always the case.
PS, with this spec i never hear a complaint from any of the operators, except when the server slows down (my next port of call).
Case : mAtx mini tower with 400w power supply (Macron 385 Black)
Fdd : Nil
Hdd : 80g SATAII, 8m cache, 7200rpm (Seagate)
Cpu : Core 2 Duo E6600 2.4Ghz, 2m l2 on-die cache, 1066 Mhz fsb,
socket 775, EM64T & XD (Intel)
Motherboard : Intel DG965 chipset, 1s / 1p / 6usb2 port with 4 x SATA, udma & fdd controller on board (SSCK Intel)
Memory : 4 x 1024m ddr2-533 PC-4200 (Kingston)
Video card : 256m PCIe 16X graphic accelerator (nVidia Quadtro FX1500 Leadtek)
Monitor: Dual 17" Monitor. That widescreen 24" (and up) is still a little to pricey, hopefully the price will drop a little more...
ā2007-02-15 07:18 PM
