Book Setting error in ArchiCAD 21. Can not set revision
There are some File in archiCAD 21 Error with the Book Setting pallet. The Book Setting open too large. We can not set the revision.
Please help as soon as posible.
11 Replies 11
runxel
Had the same problem with a particular file which was migrated to 20, but is not teamwork.
Trying to close the window will crash Archicad.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello all,
I looked into it, and it seems like this should be fixed in the next updates of ARCHICAD 20 (70xx) and ARCHICAD 21 (50xx) to some extent. They both should be released this month.
In this update we tried to fix some reasons that can make the layout books faulty, but there might still be some issues left. If after installing the updates you still run into the problem, please let us know, so we can look into what might have gone wrong.
An open & repair should indeed fix the problem anyhow (this is a fix for the already faulty state that we included in the current updates).
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
