RCA
CPU vs GPU Archicad 25
Good afternoon,
I wonder if the Archicad 25 in terms of rendering with MAXON uses the CPU or GPU?
I can't configure for GPU and rendering is done by the CPU.
Is this setting possible?
4 Replies 4
Pretty sure maxon is all cpu, programs like twinmotion utilize the gpu
RCA
So it's not even possible to configure Archicad 25 to work via GPU?
By the way, does Archicad 25 work with single core or multicore?
Lingwisyer
Guru
I believe the Redshift renderer uses the GPU, but that requires you being on an active SSA...
If you have hardware acceleration active, which I think is the default, your 3D window should be rendered via the GPU.
Regarding multicore workloads: https://community.Graphisoft.com/t5/Setup-License-articles/Multiprocessing-and-Archicad/ta-p/303631
Ling.
Laszlo Nagy cpsvis
maxon render modes:
#1 standard, only CPU
#2 redshift, only GPU
AC 6.5-28 | Twinmotion 2024| i9-11900K | RTX 3060 12 GB | 64 GB | WIN 11
