Cadimage Accessories Tools
Scott Bulmer
Using the Cadimage Accessories Tools add on for AC9.0, we are experiencing an issue that we can't find in the user's manual and are unable to resolve. Please see attached image.
When using the roof tool set to shingles, the edge tile (rake) raise up proportionate to the width of the barge board. Further, instead of the barge board extending towards the wall when set, it extends further out away from the rake side of the building causing the edge tile to fall within the board and not lap over the board normally.
Can someone knowledgable in the use of this add-on please advise me how the settings should be to correct this issue? Thank you for any comments.
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
10 REPLIES 10
Scott Bulmer
Nudge wrote:
try playing around with the "Fascia & Barge Drop" fields, i have had issues and these seem to fix my problems.
Nudge, we were unable to make your suggestion work even with the most recent update released today. Thank you for your thoughts though. The Cadimage people are looking at this I think.
Ciao
Scott
