Can I remove CodeMeter on BimCloud server?
Is it necessary to have CodeMeter installed on a BimCloud server that doesn't have a hardware key on it?
Does a BimCloud server require CodeMeter service's installed on the same server to run?
Key's are located on other servers.
Erwin Edel
Since we have software key, this might work differently, but we have codemeter running on our server to host the software key and we also need it on our workstations to read the key. I would imagine there is no difference between the key for archicad or the one for bimcloud.
Maybe ask your local support for a quick answer
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Noemi Balogh
BIMcloud Basic all alone does not need CodeMeter, but because we let customers upgrade to BIMcloud directly from the application, we also install CodeMeter with it. You can uninstall CodeMeter from your server computer if you don't have BIMcloud licenses here.
Noémi Balogh
Community Expert, Admin
