Installation & update
Can't find command promt! Need some help.
I can't find Command Prompt, that I believe used to be i the control box. There is no longer a "open/close prompt box" button in the control box.
Does anybody know how I get it back? I am in desperate need for its trusted help;)
Thanks
5 REPLIES 5
Thanks
Command prompt? What do you find there? Or do you mean coordinate palette?
What version of ArchiCad?
The command prompt is a section in the control box that gives you instructions on what to do when using a specific tool. It's super good when your are not familiar with a tool. Instead of guessing you just read the instructions! It's Archicad 9.
Link
It's called the Statusbar and can be reactivated under the Window> Palettes menu.
Link.
Nothing changes when I choose hide/show statusbar, the control box still looks the same, and it doesn't pop up anywhere else either. I's lost! Buhu..😉
Nah, it's not... there is a name in your location that is Sweden, and if so, you probably could swedish?
In Swedish :
Kör du Windows XP och någongång haft så startmeny göms när du inte har musen längst ner?
Isf. ställ den till att inte gömmas
Sen minimera ArchiCad och sen maximera, ibland har statusfält en förmåga att gömma sig utanför skärmen.
