Installation & update
SOLVED!
Can't get the window frame back in the Tab bar
Britt
I tried out a higher resolution window size to see what it would do with the quality of the axonometric on the lay-outs. When putting the window size higher, the screen 'came out' of the original tab bar. This is normal.
But now I can not seem to put it back into the original tab bar. I put the Window size settings back to the default mode, but it still remains a separate window.
Does anyone know how to fix this? Maybe important: I work with a macbook.
Thanks in advance!
1 ACCEPTED SOLUTION
Solution
Britt:
It should be part of the standard Work Environment. You can add it to your Work Environment with the Dock/Undock Tab command.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
4 REPLIES 4
David Maudlin
Britt:
In the menu bar, look at Window > Dock Window 3D.
David
Hi David,
Thank you for your reply!
Can it be that the option Dock Window 3D is not among the options? (see image)
I can not find it 😅.
Kind regards,
Britt
Solution
Britt:
David
It worked. Thank you so much!
Kind regards
