Cannot open .pln from another computer!
Ok so here is my issue, i have a file that i copied from my work computer and took home to work on it. well after two days of work i finished saved and brought the file back to work. now my work computer when i try to open that same file archcad crashes when the module gets to copy header. please help
4 REPLIES 4
Try these:
1. Create NEW project with story settings as in the old one
2. MERGE the old project to this new project: File/File Special/Merge...
YOU ARE A LIFE SAVER!!! THANKS YOU SO MUCH!!
THE ONLY THING I CANT COPY IS THE STORY VIEWS WILL I HAVE TO DO THAT SEPERATE?
With Merge you can import:
1. Virtual Building (NO Views; must be recreated)
OR
2. Layout Book
You decide what is important!
