Cannot read plan file/Repair process failed/
Hello
Hibaüzenet nélkül elmentettem egy fájlt. Másnap nem tudom megnyitni. Se a pln, se a bpn formátumút. Másik gépen, másik mappában sem. Hogyan tudnék hozzáférni egy heti munkámhoz, ami így bentragadt a fájlban, legalább részlegesen?
I saved a file, normaly, with no error message. Next day I cannot open it. Neither pln, nor bpn. Neither tried on other maschine, nor from other folder. How could I get acces to my work, that closed to this broken file? At least partially?
11 Replies 11
Erika Epstein
Have you tried opening the back-up file?
Do you have a backup drive?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I tried to open the .bpn file too. This is the back-up?
There is an AutoSave Folder in my maschine, but in this folder and subfolders there are no files wich could I associate to ArchiCAD, or any other application, so it isn't seems could solv my problem.
Did you fix that problem? I have the same message on .pln and .bpn files?
I saved a file, normaly, with no error message. Next day I cannot open it. Neither pln, nor bpn. Neither tried on other maschine, nor from other folder. How could I get acces to my work, that closed to this broken file? At least partially?)
I have the same problem did u fix it plz?
What error message do you get when you try to open it?
Have you tried the 'Open & Repair' option when opening a file from the file open dialogue.
David Bearss
Has anybody found a solution to this. Started out of the blue for me too. .pln nor .bpn will not open.
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
David Bearss
Also by the way the open and repair locks up.
David Bearss
Alienware 17 R5
While waiting for any info on what can cause this process to fail... I believe that ArchiPLUS (SSA) subscribers can send corrupt files to their local tech support for analysis / recovery (if possible). Might be worth a shot, David, before the weekend?
Not that this will help recover your file but a regimented backup strategy will reduce downtime / lost time.
We do two full backups (1 on site, and 1 offsite) every night plus incremental backups mid morning and mid afternoon. At worst case we lose only a few hours work which never takes as long to redo as when done originally (as the thinking has already been done)
Regards,
Scott
