2004-04-06 03:52 PM
2004-04-21 11:46 PM
Amanda wrote:amanda
I tried the slab method as well on a dedicated ceiling layer, but I can't figure out how to give the slab a fill to show the acoustical tile. Again, is it a setting or am i going to have to draw a fill over all of the slabs in order to get them to show up in plan and section?
I've gone ahead and done the RCP using the slab+fill method for now with the Tile 24" fill type."link to fill origin" is the user origin. "link to project origin" starts the fill at project zero (0,0). you can change this at any time by toggling the buttons in the fill tool settings or in your info box palette. to change the fill origin point and its orientation simply pick up the each end of the fill handle in turn (with the fill selected) and move or rotate - see the attached screenshot: the one on the left is "link to project origin" so there is no 'fill handle' visible. the one on the right linked to fill origin shows the editable handle. one end moves the origin, the other is the angle of rotation.
Within the fill settings, I chose "link to fill origin", but I can foresee problems with that when the electrical designer starts placing lights in there. Is there any way to link the fill to a user origin if I need to in the future?
2004-04-22 04:42 AM
2004-04-22 09:05 AM
Amanda wrote:I think you have already achieved what you need. The Fill will display an anchor point and fill direction reference line which can be freely adjusted to suit your ceiling layout. The Fill anchor may be hidden though - look at the 'Fill Handles' setting under 'Options/Display Settings'.
2004-04-23 03:32 AM
