Cineware using memory and has never been used
Rick Thompson
I typically have 5 or more instances of AC open.  I have never needed Cineware or tried to use it.  When I look at my Mac's memory usage each open instance is using a lot of memory for Cineware.  Is there away to turn it off?
Thanks
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
4 REPLIES 4
Aaron Bourgoin
Have you tried killing it from the Activity Monitor window?
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
Rick Thompson
I thought about it, but it would just come back each time I open AC so didn't bother.
Thanks
Rick Thompson
Mac Sonoma AC 26
I’ve noticed this too and queried with support. Never really got an answer as to why.
Lee Hankins
macOS Sequoia (15.1.1)
I think it is because Cineware (Cinerender) is basically a separate program running inside Archicad.
If you look in the Add-on Manager, you will see it there, but it can't be turned off as it is actually part of the program.
