ā2009-10-03 01:14 AM
ā2009-10-03 01:52 AM
Steve wrote:Checking in from on the road.... have not heard of this before, Steve, and find it highly unlikely. I cannot image why the server would care how a local copy of ArchiCAD is licensed.
I was just informed by my local distributer that you can not mix code meters with the old dongles. Everyone using the server has to have the same kind of software protection devise
ā2009-10-03 02:11 AM
ā2009-10-03 02:30 AM
ā2009-10-03 04:38 AM
ā2009-10-05 06:37 PM
Steve wrote:Steve,
I was just informed by my local distributer that you can not mix code meters with the old dongles. Everyone using the server has to have the same kind of software protection devise.
Can a person order a new ArchiCAD 13 with a dongle instead of a code meter stick so they can log into a dongle server?
ā2009-10-05 07:35 PM
gkmethy wrote:With all do respect, there would be no reason for you to presume what my distrubutor has told me if Karl had not censored my post.Steve wrote:Steve,
What your distributor probably told you is that it is not supported to have two keys of different kind in the same office. So you should either have the new Codemeter stick, or the old WibuKey, but not both in the same network.
This has nothing to do with the BIM Server. If two offices collaborate using the same BIM Server, it does not matter at all if one has CodeMeter and the other WibuKey.
ā2009-10-05 07:58 PM
gkmethy wrote:If an office can not collaborate with it's own teammates unless they are all using the same kind of dongle how can it make no difference when they collaborate with another office using the BIM server.Steve wrote:Steve,
ā2009-10-06 09:58 AM
Steve wrote:Steve,
The BIM server is how they are able to collaborate in the office too isn't it?
Also, can you confirm that license borrowing is not actually available in this version of ArchiCAD 13. (See ArchiCADWIKI)
Using the CodeMeter Control Center to transfer a license, can that be to the CodeMeter or Flashdrive of our choice ?
Has any one tried it?
ā2009-10-06 05:51 PM
