Installation & update
Codemeter Key with 2022 MacBookPro 16 (USB-C only)
Gene Kniaz
Hi all:
So this probably has a very obvious answer since it doesn't look like anyone has posted about it, but how do I get Archicad to "Authorize" without a USB-A port - will a simple cable adapter (i.e. usb-c to usb-a) work? I looked in the Archicad License Manager app to see if there was a way to "convert" the CM key to a software key, but I didn't see any indication that's do-able. I'd like to keep the CM key anyway since it makes it easier to move between my iMac and the new laptop.
Thanks,
GK
Gene Kniaz, Architect
Principal | SPIRAL ARCHITECTS
Tucson, AZ, USA
AC6.5-AC28 Intel i9 10c iMac AMD RP 5700 XT 16 GB 128MB
Yes, the adapter will work. Single, or USB hub.
Thanks Ignacio!
GK
Tucson, AZ, USA
